New project: Volvo EC480EL |
Pieter_dj
Maßstab: 1:14,5 Wohnort: Amsterdam
Level: 23 [?]
Erfahrungspunkte: 55.113
Nächster Level: 62.494
Hello Everyone,
My name is Pieter and from Holland. I would like to introduce my new project: 1:14 Volvo EC480EL (new type). Just received the first aluminium lasercut parts for the boom and dipper arm. At the moment I'm drawing the upper part of the bagger (cabin, hood etc.). The idea is to built two simultaneously.
Thank you!
[img] [/IMG]
24.12.2016 14:24 |
| RE: New project: Volvo EC480EL |
vectragts
Maßstab: 1:14,5 Wohnort: Zell am See
Erfahrungspunkte: 274.039
Hallo Pieter
Super Projekt da werde ich mal drannbleiben.
25.12.2016 10:30 |
Pieter_dj
Level: 23 [?]
Hello again,
First steps have been taken, the right boom side is bend. Pleased with the fitting.
28.12.2016 23:12 |
Pieter_dj
Level: 23 [?]
Guten Abend,
A few extra things have been done on the boom, attached the boom cilinder pivot points and some other minor things. Hope to gain some more progress later this week.
Ps. I understand and can read Deutsch, but I can't write it properly ;-)
03.01.2017 22:36 |
Alfarosso
Maßstab: 1:14,5 Wohnort: Klagenfurt
Erfahrungspunkte: 285.695
Hallo Pieter,
sehr schön was Du da baust! Den Arm aus Aluminium zu bauen finde ich super, das spart Gewicht!
Die hydraulischen Zylinder hast Du selber gebaut nehme ich an?
Lg aus Österreich
__________________ Liebe Grüße
05.01.2017 00:41 |
Pieter_dj
Level: 23 [?]
Test fitting the top plating:
05.01.2017 10:20 |
Pieter_dj
Level: 23 [?]
It's going to look like a boom!
08.01.2017 22:45 |
KallleSwe
Erfahrungspunkte: 319.330
09.01.2017 17:22 |
Pieter_dj
Level: 23 [?]
Hallo Christian and Kalle,
Thank you for the compliments!
Tonight I installed the top plating and fitted the hinge points for the dipper arm. So far so good. Hopefully I can finish the boom this week to start with the dipper itself.
Have a nice evening!
09.01.2017 23:26 |
Alfarosso
Good morning Pieter and Volks,
a late-time-answer deserves an early reply!
Looking forward to write many compliments to this project! I hope that I very soon can start my own thread here, but I was scared, i´m a completely nut when it comes to electronics
anyway a good friend of mine has declared yesterday to help me out, YES!!
Go on Pieter, it´s a wonderful project! Happy working, my god, i´m late, i have to go!!
10.01.2017 06:40 |
DopeX
Level: 19 [?]
Erfahrungspunkte: 20.456
Nächster Level: 22.851
Hey Pieter,
nice project and nice to see you making good progress. Always keep us updated!
Br,
Hannes
11.01.2017 17:25 |
Pieter_dj
Level: 23 [?]
Evening!
A little update of the hinge point details I worked on. Obviously the screws will disappear with filler and paint in a later stadium.
11.01.2017 23:42 |
Pieter_dj
Level: 23 [?]
Good evening,
Again a little update. The underside plating of the boom is done and the two hinge points are ready. Only a little top and end plate to go before I will screw and glue it together permanently.
Looking forward to start with the dipper arm.
16.01.2017 23:19 |
Pieter_dj
Level: 23 [?]
Evening!
After a short hiatus due work I started to work on the dipper arm. Just drilling, tapping and test-fitting at the moment.
Stay tuned ;-)
31.01.2017 22:27 |
Alfarosso
Hi Pieter!
Nice work!!
I have one question about the screws, you said they will obviously disappear after filling and painting, of course they will but:
Do you use screw glue before painting? I´m asking because it would be awful when screws getting loose and the filler with the paint popping out...
Maybe it´s a silly question, i don´t know if force-moments can loosen the screws when working with the excavator...?!
Schöne Arbeit!
Ich habe eine Frage bezüglich der Schrauben, du sagtest diese werden unsichtbar nachdem diese aufgefüllt und lackiert werden, klar werden sie das, aber:
Verwendest Du Schraubenkleber / Schraubensicherung? Ich frage weil es furchtbar wäre wenn sich die Schrauben durch Kraftmomente lösen würden und der Kitt / Spachtelmasse rausspringen würde nachdem bereits alles lackiert ist...
Das ist vielleicht eine dumme Frage aber kann es beim Arbeiten mit dem Bagger nicht passieren das sich durch Kraftmomente die Schrauben lösen können?
Lg aus Kärnten!
01.02.2017 07:01 |
Pieter_dj
Level: 23 [?]
Hello!
Good question. I was planning to glue all the screws with UHU end fest 300 and some major parts as well. I don't have access to a (tig) welder, so screwing it together was the way to go. I also thought about 3D printing, but I leave that for the counter weight and some other parts.
Greetings from Amsterdam
01.02.2017 10:00 |
Pieter_dj
Level: 23 [?]
Good Evening,
Again some work on the dipper arm. In the meanwhile I'm also drawing the construction for the bodywork. Slowly but surely.
Cheers!
Pieter
19.02.2017 21:59 |
Pieter_dj
Level: 23 [?]
Good evening again,
Another evening with a bit of progress. The dipper arm is almost finish, only the top-plating and everything can be glued together. Ver pleased with the protection strips on the inside of the dipper arm. Next up is the boom connection en base chassis.
Happy building!
Pieter
23.02.2017 23:00 |
Views heute: 129.404 | Views gestern: 785.064 | Views gesamt: 348.292.594
