How much force? |
Robse
Maßstab: 1:14,5 Wohnort: Dänemark
Erfahrungspunkte: 143.815
Guten tag :-)
First of all, sorry for my non-German. I hope that I one day will be able to meet you all in your native language, but until then I have to stay with English.
I am in the design phase of the crane boom cylinders, on my 1:14 LTM 1500-8.1... but I have a huge problem. While I can calculate how much I will be able to lift at the end of the boom, I can not find out how to include the weight of the boom it self in the calculation.
My question therefore is: How much force will the orange vector need to push with, in order to lift the boom?
Data:
The boom pivots around the red spot to the right.
Boom length: 4 meter
Boom weight: 12 kg (mass)
Distance pivot-point to point where orange vector lifts: 0,6 meter
Can anyone help me please? My head is spinning out of control over this, and I cannot agree with my self how to calculate.
Bis dan,
Robert Holsting **** www.robse.dk
30.09.2014 15:02 |
Erfahrungspunkte: 10.359.409
Hi there,
you need the center of gravity! If the boom is straight and equal from the beginning to the end then you find center of gravity right in the middle. Now you have the length (i.e. 2m) and a force (12kg x 9.81) round about 120N --> 240Nm. To get the force at the cylinder pivot point you need to calculate this way: 240Nm : 0,6m = 400N (40Kg).
this calculation is for a horizontally boom and a vertical direction of Force!
30.09.2014 16:25 |
Erfahrungspunkte: 27.672.900
There are detailed ways to do this, but a rough approximation is to assume the boom is weightless and half its actual weight is placed at the one end and the other half is at the other end (the pivot point and hence does not contribute to the required lifting force).
30.09.2014 22:42 |
Robse
Thank you all very much. I was afraid that the force needed was as high as 400N, but also happy that I did not go ahead and build without this taken into consideration. :-) I need to re-think my design.
Amazing how far and wide our model building takes us..
01.10.2014 07:52 |
Robse
Oh, great. :-)
I am aiming at the full picture, but was missing the boom as an isolated load.
I am actually working on a formula that includes the following information:
Mass, boom,
Mass, hook,
Center of (boom)gravety,
Angle between cylinder and boom,
Angle of boom vs. horizontal,
Cylinder power,
Distance, pivot point of boom -> point of lift (cylinder)
Distance, pivot point of boom -> tip of boom,
-all this to find out how strong my cylinders must be, and later make a load-chart. If I make it, I'll make an online version like the other (crane)engineering tools on my web.
I look forward to your input, and thank you very much for taking the time. :-)
01.10.2014 10:34 |
Dave
Erfahrungspunkte: 263.425
Hi Robert,
I found some draft with angles and distances, but not the calculation... tomorrow I will have more time to look after it. In the worst case I have to calculate again, but that would take a bit more time.
By the way, the time I spend on it will be a benefit for me as well
01.10.2014 22:36 |
Robse
Thank you very much !
When I get close enough to my own pc again, I will try to show what I got so far.
Brgds, Robert
02.10.2014 14:18 |
Dave
02.10.2014 20:11 |
Dave
At this weekend, I will try to complete the calculation with an erected boom and some weight at the hook.
02.10.2014 20:25 |
Robse
Hi Dave,
Thank you VERY much!
I will sit down with my calculator and make a calculation for my setup (Need to redo a lot, I can see), and see what kind of numbers I reach., but I can already agree with you: I AM supprised: That IS a lot of force, just to get the boom up. :-)
I'll be back.. and once Again: thank you for taking the time.
Brgds,
Robert
02.10.2014 20:25 |
Robse
Hi Dave,
Two small questions, please:
The "80" on the left, distance between center of boom and lower point of cylinder is not used, right?
Where are the "7,13 degree" measured?
(Cylinder angle in ref to boom?)
Brgds,
Robert
02.10.2014 21:05 |
Dave
The '80' is a '40'
On the bottom of the paper is a triangle of the forces/dimensions, that's what I needed to get the 7,13°. Yes, it's the angle between boom and cylinder.
02.10.2014 21:31 |
Robse
02.10.2014 21:37 |
Robse
Hi Again,
It looks as if I might get away with it a little easier than the example, unless I messed up that is.. :-)
This example is for when the boom is not extended, and horizonal.
The strange PI() and /180 in the SIN and COS calculation is caused by Excel. Excel reads radians as standard, everyone else uses degrees... Thus the conversion.
I'll Work on it more, and add more variables... load capacity, boom angle, extended boom etc.
Brgds,
Robert
Dieser Beitrag wurde 1 mal editiert, zum letzten Mal von Robse: 03.10.2014 19:10.
03.10.2014 19:06 |
Robse
Hi again,
Well... I have got a little longer, but not quite there yet.
First I can calculate the power needed to raise the boom if it is fully horizontal, and fully extended (3,4m max length) (Worst case scenario):
Pic 1
I then use that number to calculate the available power used for hooks and load:
Pic 2
What would be nice is to merge the two... so you can input cylinder power, boom angle and level of extension, and then get "max load". To get to that, the first formula must be extended to include boom angle.. and then the two formulas must merge.
Best regards,
Robert
1.jpg (57,17 KB, 176 mal heruntergeladen) 2.jpg (73,11 KB, 205 mal heruntergeladen)
Dieser Beitrag wurde 2 mal editiert, zum letzten Mal von Robse: 09.10.2014 08:56.
09.10.2014 08:53 |
Dave
Good morning Robert,
the same problem as I had, merging tese calculations
Sorry for not-answering in the last few days, I have to get my workshop ready until the electrcian comes on saturday to connect my new fuse box
09.10.2014 09:13 |
Views heute: 8.679 | Views gestern: 53.824 | Views gesamt: 256.116.258
