Excavator from malaysia |
yhng
Level: 22 [?]
Erfahrungspunkte: 47.637
Nächster Level: 49.025
Hello All, I am new here, i from Malaysia,
In here i want share my homemade rc excavator
as picture below
29.10.2012 09:31 |
yhng
Level: 22 [?]
Excavator Arm ( aluminium )
29.10.2012 09:35 |
Erfahrungspunkte: 27.772.547
Hi and welcome here
I have moved your excavator into its own thread.
It looks nice - what scale is it?
29.10.2012 15:24 |
Level: 53 [?]
Erfahrungspunkte: 18.714.613
Nächster Level: 19.059.430
29.10.2012 19:42 |
Erfahrungspunkte: 10.401.388
Hi there!
good job! All out of Aluminium?
29.10.2012 22:09 |
yhng
Level: 22 [?]
30.10.2012 01:02 |
yhng
Level: 22 [?]
Thanks Seilbagger,
i agree, selfmade is always the best.
30.10.2012 01:04 |
yhng
Level: 22 [?]
Hi Kette1zu8,
Thanks, 80% is made by aluminium,
may i ask some question ? whats material yours using for driver room ?
i used plastic sheet, but not very well for look, and can i fill pneumatic oil for operation hydraulic pump, because i use pneumatic cylinder for arm, if i fill hydraulic oil, my cylinder got big problem,
p5.png (63,05 KB, 596 mal heruntergeladen) p4.png (57,15 KB, 595 mal heruntergeladen)
30.10.2012 01:14 |
Pneumatic oil is only intended to be added to the air of a pneumatic system.- It lubricates the cylinder.
The task of the oil is different in a hydraulic system - here the oil transmits the power.
I am therefore not quite sure what you want to do.
You can use pneumatic cylinders as hydraulic cylinders, but it's not ideal and you will need to make sure that the hydraulic oil is compatible with the material used for the seals.
30.10.2012 01:42 |
yhng
Level: 22 [?]
02.11.2012 09:37 |
yhng
Level: 22 [?]
02.11.2012 09:40 |
yhng
Level: 22 [?]
hand made
02.11.2012 09:43 |
yhng
Level: 22 [?]
02.11.2012 09:44 |
yhng
Level: 22 [?]
05.11.2012 02:40 |
Great work doing all this with simple tools!
But I think it is quite a bit larger than 1:14?
05.11.2012 13:07 |
Erfahrungspunkte: 52.386.307
Der ist doch 1:10
05.11.2012 13:57 |
Erfahrungspunkte: 5.661.059
Trotzdem saubere Arbeit.
Also good work
06.11.2012 00:06 |
yhng
Level: 22 [?]
change the driver room
2013-01-21 18.40.56.jpg (78,22 KB, 184 mal heruntergeladen) 2013-01-22 17.47.08.jpg (87 KB, 184 mal heruntergeladen) 2013-01-22 17.47.17.jpg (100 KB, 183 mal heruntergeladen) 2013-01-22 18.24.48.jpg (92,10 KB, 182 mal heruntergeladen) 2013-01-22 18.25.16.jpg (88,36 KB, 187 mal heruntergeladen) 2013-01-22 18.25.44.jpg (104,21 KB, 184 mal heruntergeladen)
23.01.2013 06:57 |
Views heute: 32.823 | Views gestern: 321.762 | Views gesamt: 259.179.639
