Bruder Cat 320 conversion |
ari
Erfahrungspunkte: 248.601
Or should I use this pipe Schaluch 4/2,5mm Bestell-Nr. H058
10.03.2012 20:58 |
ernie28ernie
Erfahrungspunkte: 382.938
H052 is ok, but:
4/2,5 is far better, as you have a much lower resistance!
If you can use the M4 tube connectors it would be great, as the M3 cannot have 2,5 inner diameter
Leimbach is offering PU pipes, which are soft. So you can have comarapble tiny corners, but you are near/over the specification of the pipes.
Better would be PA pipe, which is not so soft, is specified for much higher pressures (25-50bar), but you have to use bigger radiuses.
Yours,
Martin
11.03.2012 10:22 |
ari
Original von ernie28ernie
H052 is ok, but:
Yours,
Martin |
Thank you Martin!
11.03.2012 16:32 |
ari
11.03.2012 16:38 |
ari
Comments?
23.03.2012 08:35 |
Erfahrungspunkte: 20.955.007
To that Point you have done a great work ,i think when you ar done it will be a more as beautiful conversion .
23.03.2012 12:49 |
Spiertz Transporte
![images/avatars/avatar-818.jpg](images/avatars/avatar-818.jpg)
Maßstab: 1:14,5 Wohnort: Waldfeucht
Erfahrungspunkte: 160.799
It looks very nice , good job well done
__________________ Schöne Grüße aus dem Selfkant
Marcel
www.facebook.com/marcel.spiertz
06.04.2012 09:17 |
ari
New pictures. Bucket is ready and boom also.
![](http://lh4.googleusercontent.com/-pxYdvsgAJFQ/T3n1ZlYEL3I/AAAAAAAAAwk/s2UuQAZMZGk/s720/WP_000130.jpg)
![](http://lh3.googleusercontent.com/-U1pIUpWCFXQ/T3n1eAjBCxI/AAAAAAAAAw0/pw6bLhF6sW0/s720/WP_000132.jpg)
![](http://lh6.googleusercontent.com/-cSaa-aszpwM/T3ycedVw-7I/AAAAAAAAAyM/14t-pdvtoZ4/s720/WP_000143.jpg)
06.04.2012 16:55 |
caterpilar
Erfahrungspunkte: 504.020
Looks amazing Ari. I will take some time to collect all the bits and pieces and then I will start doing my conversion. Would be helpful if you could share more details about the parts you bought.
Keep up the nice work!
10.04.2012 00:35 |
ari
Cylinders are almost ready. Piping is the next step :-)
07.05.2012 10:19 |
LR 634
![images/avatars/avatar-792.jpg](images/avatars/avatar-792.jpg)
Erfahrungspunkte: 759.890
14.05.2012 18:43 |
ari
07.08.2012 22:04 |
Erfahrungspunkte: 5.661.064
08.08.2012 03:28 |
ari
And it is ready
![](http://lh4.googleusercontent.com/-JBAeF_E1sTQ/UD0WtFWyHiI/AAAAAAAAA9o/RIcVvJ429HQ/s640/WP_000567.jpg)
01.09.2012 20:12 |
01.09.2012 23:05 |
Erfahrungspunkte: 10.401.396
awesome!
01.09.2012 23:27 |
Level: 53 [?]
Erfahrungspunkte: 18.714.624
Nächster Level: 19.059.430
16.06.2013 22:00 |
Views heute: 34.668 | Views gestern: 321.762 | Views gesamt: 259.181.484
