Bruder Cat 320 conversion |
Erfahrungspunkte: 10.399.716
if they´ve got the same resistance and if they are linear or logarithmic like the rotational ones, then you can change them.
17.10.2011 22:16 |
Erfahrungspunkte: 27.768.578
The pots in the 9x are 5kOhm pots, which are used in their full range.
I have converted two 9x radios and as the pot works as a voltage divider, it is not critical. You can use 10kOhm or even 50kOhm pots. (I've done so.)
Some of the Futaba sliders have additional resistors in their connection, so if you connect them to a radio that does not expect those resistors, the pots will not give the full range.
You can avoid this by:
1. Buying regular sliding pots, but these typically do not have the centre detent of the Futaba units.
or
2. Getting the Futaba F1501, it does not have the additional resistor and is a 10kOhm pot.
If you swap the pots, make sure to connect the wires properly
17.10.2011 22:38 |
ari
Erfahrungspunkte: 248.561
Thanks for the help. Turnigy is now ordered.
How about gearmotors for tracks. What gear ratio is most used in excavators as a drive motors?
31.10.2011 21:43 |
Erfahrungspunkte: 11.249.838
Many Bruder conversions use modified servos, or you use RB 35 200:1 from Conrad.
Gear motors have more power, but they are bigger. I use gear motors in my excavator.
31.10.2011 22:53 |
I think gear ratio is not the measurement you should be looking for.
Torque and rpm at the final drive are more helpful.
I think the rpm of the chain wheel of most excavators is around 15 rpm?
Not an excavator man, so you might want to check that.
31.10.2011 22:56 |
ari
undercarriage parts are allmost ready
![](http://lh6.googleusercontent.com/-gHBq7rBXf0U/TtvX52DPMqI/AAAAAAAAAkc/AXB_QJ53CSw/s912/alavaunu.JPG)
I have question about the superstructure rotation motor.
What kind of motor is best and what gears you are using in undercarriage and pinion.
06.12.2011 21:12 |
ari
I have question about Cat colours. What is correct code for the yellow color used in Cat 325
30.01.2012 09:21 |
Hi there,
let me translate this question for Baggerkalle! He´s the man, who should know. But I believe, this colour is not available in Homeworker-Stores.
@Kalle:
Welcher Farbton ist denn das CAT-Gelb des 325ers? Hat die FArbe einen Code bzw. wo kriegt er die her?
30.01.2012 12:24 |
Erfahrungspunkte: 52.379.813
Das ist ja das Problem die Farbe bekommste nur bei CAT und die sagen auch nicht was für ein RAL Ton das ist !! Mann kann hier bei CAT die Farbe Kaufen in Sprühdosen als Reparaturlack und da ist auch keine Nr. drauf . Oder in kg Dosen .
30.01.2012 12:50 |
In jedem Land gibt es CAT sevice . Wo auch Werkstätten sind . Die müßten die Farbe haben .
Gruß Kalle .
30.01.2012 12:58 |
I translate it for you:
Kalle said, you will get no answer from CAT what kind of color they use. But you can get the color from the CAT service directly. In almost every country is a CAT dealer/ service. Just asked him for repair varnish. You can get it in a spray can or in buckets.
30.01.2012 13:38 |
ari
30.01.2012 20:40 |
ari
Hello,
Small update. Undercarriage is now assembled. I also get parts for the boom and uppercarriage.
And picture
24.02.2012 19:43 |
LR 634
![images/avatars/avatar-792.jpg](images/avatars/avatar-792.jpg)
Erfahrungspunkte: 759.763
Hello,
the Undercarriage looks great.
Nick
IG – STONEBREAKER-AREA
24.02.2012 19:46 |
ari
05.03.2012 11:13 |
ari
New pictures
![](http://lh4.googleusercontent.com/-ED_aEQ--Iqk/T1eyGfNv4PI/AAAAAAAAApE/D7gbFJfDqus/s720/WP_000064.jpg)
07.03.2012 20:25 |
Looks great! I like it
07.03.2012 20:28 |
Views heute: 103.488 | Views gestern: 256.315 | Views gesamt: 258.928.542
