Hitachi Zaxis 470 LCH 1:12 |
KallleSwe
Erfahrungspunkte: 327.565
Thank you guys!
Well it not much to do on this one, im just adding small things to finish it up right now, today i added some hydraulicprotection over the hoses, added 2kg to the counterweight, it weighs 4.5kg now, that brings the whole machine to a total of 34.7kg as it is now!
I have also used the mixers in my radio so that the pumpmotor work with the valves, when i open a valve the motor rev as needed and when i colse the valve the motor goes down in rpm:s, you can hear it in the videos below.
Works great and should save me some batterytime, not so hard on parts/oil and reducing heat in oil. (Thank you Frank).
Thats pretty much it for now, its getting a little warmer next week so maybe some ripper action when it softens up the snow/ice!
Filmer.
[img] [/IMG]
[img] [/IMG]
24.02.2011 22:31 |
Erfahrungspunkte: 59.422.941
Da sage mal
Gruß Baggerkalle
24.02.2011 22:57 |
Erfahrungspunkte: 24.015.521
25.02.2011 12:53 |
KallleSwe
Thank you!
A little update, i have started to make a grading bucket today, its not finished yet, i need to make mounts and some details to finish it off then my friend will weld it up for me.
I dont know if its to wide or to small overall, i have used the dimentions from a 1:1 bucket but it feels a little small or to wide, what you think?
Maybe i will make it so i can tilt it but thats not for now.
10.03.2011 20:41 |
KallleSwe
I am not an expert - I think it looks good.
I think you could make it a bit wider if you wanted, but it's not necessary.
Edit: Actually, I think it's perfect now?
Have you thought about one that can be angled? |
I said in the last post that i might do it later on, but for now it will be a fixed one, i will do that next vinter or so if i decide to do it.
I think i should have made it a little higher but it will do for now.
11.03.2011 19:39 |
KallleSwe
Added some side wearplates, now it just need to get welded.
12.03.2011 23:30 |
Views heute: 30.610 | Views gestern: 180.424 | Views gesamt: 423.798.584
