An interesting new in excavator world. |
mighty
Erfahrungspunkte: 157.772
Hi!
Sorry but I do not speak German.
There is an good new in excavator's world.
It is not a new excavator. It is an apparatus to be mounted on excavators and other hydraulic machines.
And 'what was missing in every excavator.
Transform excavators up to the real ones.
Let me know what you think.
Look here:
http://it.youtube.com/watch?v=z7r4yNBm-Y...re=channel_page
The follow is the description of autor:
"IVY-1 is an electronic system that manages the pressure in the hydraulic model (as excavators, buldozer, truck, etc..). IVY-1 is a system that can control and change the flow and oil pressure according to the conditions of use (intelligent system). Especially IVY-1 is a system capable of lowering the pressure in case of rest and water utilities to rise again when using them, as in real excavators!! To date, which allowed us simply to vary the ratio of the electric motor, which is decidedly very unrealistic and not applicable in short intervals and variables, where it is essential to have a REAL AUTOMATIC set-aside and restore the plant. In my opinion, was the last barrier to be deleted, an important but neglected barrier. An essential function, a function that the media is seen as the real heart of hydraulic, but that I know, never before tested on the scale models. This instrument is good also for buldozer, trucks and all hydraulic model."
See you.
12.01.2009 22:41 |
Erfahrungspunkte: 13.908.591
soweit ich das erkennen kann, nicht schlecht, gibts dazu auch eine Beschreibung in Deutsch, und die Preise würden mich interessieren.
13.01.2009 14:46 |
HP.Fuchs
Level: 26 [?]
Erfahrungspunkte: 104.415
Nächster Level: 125.609
mich würde mal ein schlichtes Datenblatt interessieren, ohne Laufschrift, Drehschrift, schräg reinplatzende Sterne und Ähnliches und ohne Bilder dahinter, die keinerlei Bezug zu dem Modul haben. Vielleicht geht das.
Ich schätze, ein seriöses Produkt hat sowas nicht nötig. Wenigstens kann man die klassische Musik abdrehen ...
Hans-Peter
13.01.2009 16:23 |
Werner S
VIP Mitglied
![images/avatars/avatar-541.jpg](images/avatars/avatar-541.jpg)
Erfahrungspunkte: 3.550.474
Hallo Leute, ich habe mich mit dem Hersteller direkt in Verbindung gesetzt und 8 Fragen gestellt. Mal sehen, was rauskommt.
Werner
13.01.2009 21:42 |
da bin ich mal gespannt. Aussehen tut das Teil sehr interessant. Servokabel rein, Servokabel raus und zwei "Druck" anschlüsse, oder misst der die Menge???
13.01.2009 22:01 |
Alexander v. Moeller
![images/avatars/avatar-371.jpg](images/avatars/avatar-371.jpg)
Erfahrungspunkte: 445.924
Hallo zusammen !
Zwar bin ich nie und nimmer so versiert wie Ihr im Modellbau, aber ich surfe gerne.
Vor einiger Zeit habe ich diese Internetseite gefunden:
http://www.fumotec.de/0344409ac2110f704/...1401/index.html
Startseite :
scheint von der Idee zumindest wohl die gleiche Ausgangsidee, wie zu Anfang oben zu haben :
Akkukapazität sparen.
Load sensing.
Vielleicht ist der Artikel für Euch Spezies interessant ?
Oder kanntet Ihr den schon?
Alexander
aLEXANDER
14.01.2009 00:44 |
Hallo Alexander,
Load sensing hat auch nicht der erfunden, und ein richtiges LS ist das auch nicht, denn die Menge bleibt immer dieselbe, da der Motor immer voll dreht.
Bin mal gespannt, ob Werner seine Fragen beantwortet bekommt.
14.01.2009 07:51 |
Werner S
VIP Mitglied
So, die Anworten kamen schnell. Fest steht, dass "mighty" selbst der Hersteller des Systems ist, ich hätt´s an der Mailadresse sehen müssen. Das ist aus seinem posting nicht hervorgegangen, deswegen habe ich die Fragen direkt an die angegebene mailadresse gestellt:
Hier mal sinngemäss in deutsch, gleich mit den zugehörigen Antworten.
Frage: 1 Wie ist der Maximaldruck deines Systems?
Antwort: Der Maximaldruck ist bis 20 bar erlaubt, der Prüfdruck ist 25 bar.
Frage 2: Kann dein System für Bürstenmotoren oder für bürstenlose Motoren verwendet werden?
Antwort: IVY-1 hat mit den verwendeten Motoren nichts zu tun
Frage 3: Was passiert, wenn der Hydraulikzylinder blockiert ist und der Hebel auf dem Sender ist in Arbeitsstellung? Gehen Druck und Fördermenge runter auf 5%
Antwort: IVY-1 hält den Maximaldruck (Anm. : Es wird anscheinend nur die Fördermenge abgeregelt.)
Frage 4: Wie hoch ist der Maximalstrom (A)
Antwort: Externer Arbeitsstrom hat mit IVY-1 nichts zu tun, interne Sromaufnahme ist 100mA
Frage 5: Enthält IVY-1 einen Fahrregler?
Anwort: Nein, mein Ziel ist eine Kontolle über die Hydraulik
Frage 6: Was macht die Leerlaufdrehzahl bei vollem und leerem Akku zwischen 10 und 13 Volt
Antwort: Tut mir leid. ich verstehe diese Frage nicht richtig .
Frage 7 Welcher Spannungsbereich?
Anwort: Versorgungsspannung für IVY-1 ist 4,8 - 6V DC
Frage 8: Wieviel kostet das Teil einschliesslich Versand nach D?
Anwort: Der Preis ist 480€ plus 20.- € innerhalb Europa
Hier die beiden Originaltexte, damit , wer Lust hat, selbst übersetzen kann.
1. What´s the maximum pressure of your system?
2. Is your system to use for brushles or brushed motors?
3. What happens, if the hydraulic cylinder is blocked and the shift of the RC transmitter is in working
position? Does the pressure and the oil quantity go down to 5% ?
4. What´s the maximum current (A) of the IVY-1
5. Includes IVY-1 a speedcontoller ?
6. What does idle run of the motor do at full and empty accumulator between 13 and 10Volts
7. What voltage range?
8. Last not least, what´s the price including shipping to Germany
Hier die Antwort, die ich darauf bekommen habe:
1) Maximum pressure allowed is 20 bar, but IVY-1 is tested also at 25 bar.
2) IVY-1 having nothing to do with motors.
3) IVY-1 keep and maintain the max pressure.
4) IVY-1 is not subject to external loads, the IVY-1 internal load is about 100 mAh.
5) No, many models has speed controller, my targhet is an hydraulic controller.
6) I do not undertund well this question..sorry.
7) Voltage range (for IVY-1 power) is 4,8 - 6 volt DC
IVY-1 price is 480,00 Euro.
Shipping for Europe is 20,00 Euros.
Vielleicht gibt´s irgendwo ein Miissverständnis. Meine Fragen sind damit jedenfalls weitgehend beantwortet.
@mighty: Thanks for your answers, maybe there are still open questions from other board members
Ciao
Werner
14.01.2009 18:07 |
dino
Erfahrungspunkte: 514.834
Danke Werner!
Nun wäre es noch genial, wenn Du das System mit Deinen Worten beschreibst.
Also was es genau ist.
Eine elektronische Überwachung der Servostellungen der Hydraulikventile in Kombination mit einem Fördermengen-Messer, der den Drehzahlsteller der Hydraulikpumpe "verwaltet"?
sg
dino
14.01.2009 19:07 |
Jörg B.
Erfahrungspunkte: 515.585
Hallo Werner
Vielen Dank für deine Bemühungen
Aber laut den Technischen Daten für meinen Fall Leider (mal wieder) Unbrauchbar
Bleibt wohl nur "Eigenentwicklung"
Jörg
!! Nichts ist Unmöglich !!
![](http://www.danasoft.com/sig/356252479410.jpg)
14.01.2009 21:11 |
Werner S
VIP Mitglied
Da steh ich nun , ich armer Tor
und bin so klug als wie zuvor
(J.W.v.Goethe)
Ja, lieber Dino, da bin ich aus dem Schneider, weil der Druckbereich beim IVY-1 dort aufhört, wo es bei mir erst anfängt, Spass zu machen.
Jedenfalls steuert das Gerät microprozessorunterstützt, es wird auch die Öltemperatur gemessen und in die Regelung mit einbezogen. Die beiden Nippels mit dem blauen Schlauch müssen also einen Durchfluss haben oder die Temperatur wird über Kabel gemessen. Das Video sagt über die Funktion nichts aus, weil die Manometeranzeige zeitgleich mit den Baggerbewegungen und dem Motorengeräusch gezeigt werden müsste. Ob die Regelung tatsächlich so perfekt ist, kann nur in der Praxis festgestellt werden. Wer spielt für 500€ Versuchskaninchen, Hand hoch!!
@mighty:
Anticipating an information to you: Most of our hydraulic models run with ruled pressure or oil quantity, not perfectly at all but it´s not true most models waste energy.
just a few questions more:
for what purpose are all the wires and the blue tubes?
do you have a connection plan, will you show us?
It´s better for information to make a movie without any letters . While i look at the movement of the excavator i´d gladly like to hear the noise of motor and see the manometer´s reading at the same time
ciao
Werner
14.01.2009 22:28 |
dino
Lieber Werner!
Allem kann ich widerstehen, nur der Versuchung nicht!
(Oscar Wilde)
@mighty! Please make a movie without any music in the background, just the excavator and his noise and a look at the manometer!
14.01.2009 23:13 |
mighty
16.01.2009 03:42 |
mighty
16.01.2009 04:42 |
Views heute: 114.537 | Views gestern: 233.078 | Views gesamt: 257.263.824
