CAT 320D excavator |
caterpilar
Erfahrungspunkte: 502.949
I made 1 of the 4 buckets today:
1 down ... 3 more to go ...
how do you like it??
19.11.2012 18:26 |
caterpilar
20.11.2012 16:34 |
Erfahrungspunkte: 20.919.090
20.11.2012 17:55 |
caterpilar
the excavator is entering in the final stages of construction
still to do:
- 3 more buckets to make
- some minor brazing work to the body and undercarriage
- the electronics and the hydraulics
- fixing the driver' seat --> important
- finalizing the body cover with hinges for the cap covering the engine room
20.11.2012 21:45 |
caterpilar
mounting the top of the undercarriage to the undercarriage using threaded spacers
using bolt to fix the from the top and the bottom side
bending down the 4 edges of the undercarriage top plate to create more clearance for the tracks
preparing the black cover for the engine room access with hinges
bending down the 4 flaps to enlarge the access to the engine room. following the shape cut out by laser
after bending all the flaps, I installed the black cover
22.11.2012 16:41 |
caterpilar
I was a little too quick drilling the holes for the hinges in the aluminum plate
So I had to repair the holes in the aluminum, which I did with the Easyweld flux rods. I am happy with the result.
22.11.2012 19:16 |
caterpilar
Easy access to the technical room
plenty of space for the hydraulics, battery and electronics
This video shows the end result of the assembly of all the alu parts. I do still need to make the other 3 buckets. I am expecting delivery of the motors so I can start working on bringing the model alive
http://www.youtube.com/watch?v=c7-i6RbBIQs
27.11.2012 17:45 |
caterpilar
I am still waiting for the delivery of the motors and the chains... so in the meantime I made another bucket
preparation of the baseplate with the holes for the teeth
before brazing the parts together
brazing has started
... two more buckets to make ...
28.11.2012 18:45 |
caterpilar
First package delivery today
I hope the other hydraulic parts arrive today as well
06.12.2012 09:15 |
caterpilar
the hydraulic pomp is still outstanding...
07.12.2012 11:28 |
caterpilar
07.12.2012 20:59 |
caterpilar
Ich habe schon 2 Zylinder installiert. Die anderen mache ich diesem Wochenende, wenn es die Zeit erlaubt
Na und? was denken Sie so weit?
08.12.2012 09:50 |
Erfahrungspunkte: 10.380.388
looks great! Keep going!
08.12.2012 11:26 |
caterpilar
Die Getriebemotoren sind heute angekommen ...
12.12.2012 00:08 |
caterpilar
12.12.2012 16:34 |
caterpilar
Heute habe ich angefangen die Hydraulikleitungen zu machen. 1 Seite ist fertig so weit ...
14.12.2012 16:13 |
caterpilar
Ich konnte nicht bis Morgen warten, um die zweite Seite zu tun. Das ist so viel Spaß!
14.12.2012 19:35 |
caterpilar
Hier ist der heutige Status-Update auf meinem build (Entschuldigung, keine Bilder heute)
Ich habe alle diese Hydraulik mit Ausnahme der Pumpe erhalten. Die Zylinder sind bereits auf dem Modell angebracht. Ich werde auch weiterhin die Arbeit an der Hydraulik, sobald die Pumpe kommt auch zu beenden.
Die Motoren sind ausgerüstet. Ich habe gute Qualität Tracks auf Ordnung und erwarten die Lieferung noch in dieser Woche.
Ich muss noch die Controller für die getriebemotoren kaufen. Das ist das letzte, was zu tun ist, um das Modell zum Laufen zu bringen.
Ich weiß, es gibt günstige Hydraulik-Kits etc. auf dem Markt für weniger als 300 Euro, aber ich möchte, gute Qualität Teile kaufen, um meine persönlichen Modell fertig zu machen, wiel ich es für eine lange Zeit genießen wollen.
Am Anfang meiner alu Teilesatz, verbrachte ich insgesamt 1500 €, es zu beenden off mit guter Qualität Materialien. Ich habe keine Drehbank, sonst wäre ich in der Lage, mehrere hundert Euro weiniger zu Zahlen weil dann kunte ich die Zylinder und Stahlrollen selbst machen. Das heißt also, dass ich ein gutes Preis-Leistungs-Verhältnis Bagger haben.
17.12.2012 16:41 |
caterpilar
Und die Raupen sind Heute angekommen.....
18.12.2012 18:04 |
caterpilar
Ich habe ein Upgrade von meinem Bagger gemacht. Hier sind meine neuen Ketten ...
Ketten ohne die Spannung
Mit Spannung
Ich habe ein Problem mit die Pumpe und den Motor Verbindung. Ich glaube etwas fehlt, um die miteinander zu verbinden .... weiß jemand was fehlt?
20.12.2012 19:05 |
Views heute: 153.855 | Views gestern: 178.165 | Views gesamt: 257.070.064
