CAT 320D excavator |
caterpilar
Erfahrungspunkte: 504.015
I have added a new item in my design!!
a dirt/rock separator bucket. The backplate is now available for anyone who wants it in their kit.
a few pictures below:
what do you think about it??
04.10.2012 18:58 |
Erfahrungspunkte: 10.401.307
good job!
04.10.2012 19:20 |
Erfahrungspunkte: 20.954.854
04.10.2012 19:58 |
caterpilar
Drehkranz heute in mailbox
it fits perfectly with the model
08.10.2012 20:52 |
caterpilar
I have checked the hydraulics and I will be getting cylinders from Robbe and the other Hydraulic components from Leimbach.
11.10.2012 17:28 |
caterpilar
after a very busy period, I found some time again to continue the project. I have made some modifications to the baseplate of the body and the connection plate for the boom to receive the CTI slip ring.
05.11.2012 22:58 |
caterpilar
06.11.2012 16:28 |
caterpilar
und jetzt den unterwagen.
07.11.2012 10:50 |
caterpilar
12.11.2012 11:33 |
caterpilar
12.11.2012 13:21 |
caterpilar
13.11.2012 17:38 |
caterpilar
today I put together the sprocket wheel.
I used the following items in addition to the alu cut wheels:
- piece of M2 threaded rod
- M2,5 bolt 8mm long
- M6 to 4mm part to connect the sprocket wheel to the motor
- M2 nut
detail of the connection piece
with a 6mm drill bit I started to make the holes bigger
then i used a 5,5mm drill bit to make the other holes bigger. I used a M6 steel bolt to thread the 5,5mm holes of the round plates so they would fit on the connection piece
then i drilled a 2mm hole in the middle of the connection piece so I could fit the M2,5 bolt in it to hold the last 3 round plates
thats how the front looks
the back side, after cutting of the excess of the M2 rod and adding the nut.
i decided to add 16 bolts M2 of 6mm to finish off the front
still 13 bolts to go
14.11.2012 19:11 |
caterpilar
15.11.2012 09:36 |
caterpilar
putting together the bottom rollers for the chain (5 rollers on each side). Therefore I am using a 3mm copper tube with inner diameter 2mm. When I fit a 2mm threaded rod with two nuts, its holding the sides of the undercarriage very well. Tomorrow, when time permits, I'll do the top rollers.
So, except for the buckets, there is no brazing or welding required on the model
15.11.2012 20:08 |
caterpilar
16.11.2012 17:38 |
caterpilar
first (short) video of the undercarriage. Still work in progress but happy about the result so far.
http://www.youtube.com/watch?v=1WBFo-rpPOs
Currently using the bruder plastic tracks just as a test while waiting for the delivery of the final tracks.
16.11.2012 17:49 |
caterpilar
Today i did the brazing of the cabin with Alu flux rods. Here a few pics. Enjoy!
All brazing done with Easyweld de Durafix. It worked really well and the result is nice.
I am using a normal torch to heat up the aluminum.
1. Very important is to clean the place which you want to de brazing on with the copper brush
2. heat up the aluminum till its hot (i mean really HOT)
3. only then come carefully in with the aluminum flux rods from easyweld. if you come in too early, they will melt and bulb up with an ugly result.
4. slightly rub with the flux rods on the hot aluminum and you will see it melts nice and evenly while you pull the rods over the hot surface.
Here a "walk through video of the cabin".
http://www.youtube.com/watch?v=toIhM_AYci4
18.11.2012 19:31 |
caterpilar
19.11.2012 11:45 |
Erfahrungspunkte: 52.385.993
Kenne ich Alu lötten haben wir auch mal gemacht , auf der Messe gekauft . Super Top . haben wir gedacht nach einem jahr sind die Teile auseinander Gefallen .
19.11.2012 12:27 |
caterpilar
mit Durafix fält es nicht auseinander
Schön grundig getestet
19.11.2012 13:57 |
Views heute: 15.561 | Views gestern: 321.762 | Views gesamt: 259.162.377
