[1:8] Cat966H
errikos1os
Hello this is my wheel loader made of cast iron
errikos1os
from the cat manual
errikos1os
and
errikos1os
i cut the chassis out of 6 mm steel.
errikos1os
and...
errikos1os
Front Axle Rear Axle
errikos1os
and the bucket ....36cm....
heini
Hello,
the chassis looks good and stable - also the bucket.
Du you plan planet gears in the front and rear axle? Without this further reduction you maybe become problems. The wheelloader 966 H in 1/8 have a weight about 50 kg? The tires diameter 220 mm. The forces to the differential gears could be very high.
Furthermore a good construction!
errikos1os
Good morning my friend heini no I haven't put planetary gears in, I've made them in a different way but to make a differential. In all the tests I've done so far, it has come out with ease, think I pushed 50 kilos.Thank you very much for your advice..
errikos1os
This is not a hydraulic version, it will work electrically with linear actuator 1000 newton
errikos1os
errikos1os
errikos1os
With two linear actuator 200 kilos of power together...
errikos1os
