mabuse19
Hallo Enrico,
very good work from you! I am waiting for more pictures. The parts you show us, are perfect.
Matthias
Hi Enrico,
do you`ve pictures how the hydr. rotary union was built? Also wanna see the hydraulic motor details in the drive train!
The chainlinks looks good but why there are no holes in the shoes? This could be a problem when driving through dirt because the sprocket will press the dirt more and more into the link.
...and in german
Bilder vom Zusammenbau der Drehdurchführung und Details von den Hydro-Motoren wären super.
Kettenglieder sehen gut aus, aber warum fehlt das Loch in der Platte? Könnte Probleme geben, wenn du durch den Dreck fährst, weil das Kettenblatt den Dreck immer mehr ins Kettenglied drückt.
This looks amazing, Erik!
The overlap on the tread plates looks super-realistic!
Erik79
Thanks a lot JensR, this is exactly what i wanted and i am happy that you noticed it.
Erik79
Hello everyone,
i have a new step in the construction, i have built the prototype of the open centre valve and started to test it.
The system working pressure is 22 Atm, the relief pressure is 2-3 Atm, relief current drain is 1,5-1,8 Amps and the pump run with 20% of gas. The center dead-zone of the valve is 4° per side and in zero position the cylinder is well locked and the force needed to rotate the valve is not much, so i am satisfied. I show you two photos and a video....
https://www.youtube.com/watch?v=6rOSZWjEAQI
In a few days i hope to do some tests with the load on the cylinder.
See you soon, bye.
Enrico.
Fantastic!
And nice work on the valve, just saw it now!
Erik79
Thanks JensR, you are right, the youtube link is hard to notice.
If you know how the youtube player can be linked to the forum, can you say it to me please?
See you...
Embedding is not supported, but if
YOU SHOUT REALLY LOUDLY people will notice the video link!
Erik79
Ok JensR, i'll take into account your hint for the next times...
See you soon...
tessen
an amazing job! I sit in the front row to follow your progress
thanks for sharing!
Erik79
Hi Tessen, thank you for watching!!
hubiluks
AMAZING!!!!!!!! Top Top Top !!!!
Erik79
Now some news about the internal of the cabin, some photos of the parts under construction, still to be finished.
The lateral console,
The armrets,
And the joysticks,
See you...
