Is it normal that you write "KAT" in Texas
jurgen
Das ist ein BuyChina Bagger, Sandro. Die nennen ihn Kat damit die richtige Katze ihnen nicht wegen Lizenzgebühren kommen kann. Ob's genug Änderung ist weiss ich nicht.
Sieht nicht schlecht aus und für $850USD ohne Hydraulik bezahlbar. Kann dann jeder die Hydraulik selbst aussuchen.
Gruss Jurgen
ricky
That's right jurgen I think that is the reason they spelled it like that,now to get me some cylinders and a good pump with valves and some bushings and it will be time to movesome material.
Thx
Ricky, do you have a link to the shop were you bought the excavator?
vectragts
Schaut nicht schlecht aus und der Preis . Wenn er auch das hält.
ricky
Thank you vectragts and yes I did consider that also
Ricky
Hallo Ricky,
samething new about your KAT ?
special the tracks.
ricky
Yes Christian they made some new tracks and they are pretty good now they have them black
Thx ricky
Hallo Ricky,
are the black made in steel ?
Thx Christian
Hi Ricky!
How satisfied are you with the quality of the machine?
have you had a chance to really get to work with it yet?
I understood you bought the "empty" excavator and then chose to install pump and cylinders from another manufacturer?
Best wishes
ricky
Jens,I am very satisfied with it just have to put in a little elbow grease and a lil modification and she will be perfect.
Ricky
That's great to hear!
What hydraulics are you going to use?
It seems to be a "normal" size, so you have quite a bit of choice, I guess?
PS: Where can I buy that elbow grease, mine is squeaky!?
ricky
I am getting the 18mm cylinder kits from fumotec I was gonna get the ones from rc4wd but changed my mind, the elbow grease I need some to it's been awhile
