matteoreo
Good morning to all my name is Matteo from Italy , i want share with you a project started one year ago after seeing a lot of fantastic project in this forum.
This is a reproduction of a Liebherr 984c litronic a friend of mine make the design of the machine that was cut with laser tecnology on metal.
I put some photo of the work done:
The chain came from another project of an italian constructor
this is the traction system after some test i replace the motors and the gear reduction with a strongest type.
this is the traction wheel at the time is not finished i plan to mill the holes for the bolt like the real machine ad make the liebherr logo.
This is one of my favorite image after some test i put the rotation mechanism like the original machine and works very well.
This is the final configuration for the traction at the time i will do any changes i will post that when finished.
This is the upper structure painted green.
First image with part of the hydraulic cylinder
Last week i could test the excavator and work good, at the time i am doing some modification to improve some detail in the machine.
When i do any new photo i will post here.
