Excavator from malaysia
yhng
Hello All, I am new here, i from Malaysia,
In here i want share my homemade rc excavator
as picture below
yhng
Excavator Arm ( aluminium )
Hi and welcome here smile
I have moved your excavator into its own thread. smile
It looks nice - what scale is it?
welcome in worlds best forum.
Your excavator looks very good, selfmade is always the best.
Hi there!
good job! All out of Aluminium?
yhng
Hi, JensR, is 1:14 scale
yhng
Thanks Seilbagger,
i agree, selfmade is always the best.
yhng
Hi Kette1zu8,
Thanks, 80% is made by aluminium,
may i ask some question ? whats material yours using for driver room ?
i used plastic sheet, but not very well for look, and can i fill pneumatic oil for operation hydraulic pump, because i use pneumatic cylinder for arm, if i fill hydraulic oil, my cylinder got big problem,
Pneumatic oil is only intended to be added to the air of a pneumatic system.- It lubricates the cylinder.
The task of the oil is different in a hydraulic system - here the oil transmits the power.
I am therefore not quite sure what you want to do.
You can use pneumatic cylinders as hydraulic cylinders, but it's not ideal and you will need to make sure that the hydraulic oil is compatible with the material used for the seals.
yhng
Arm complete
yhng
yhng
hand made fröhlich Augenzwinkern
yhng
Freude Cool
yhng
Engine Cover window
Great work doing all this with simple tools!
But I think it is quite a bit larger than 1:14?
Der ist doch 1:10 10 Sterne
Trotzdem saubere Arbeit.
Also good work 10 Sterne
yhng
change the driver room
