[1:14,5] Original John Deere frontaxle 7020 LF series
Kolpen
I wanted my John Deere tractor to drive more realistic. I have a super smooth motor (faulhaber) and ESC (servonaut) and Digital steering servos programmed to move very slow.
But the turning radius could be better and also a real JD tilts the wheels when turning...
So here is some progress pics from the build.
Camber angle is 5 dgr. and Caster angle is 12 dgr. to give the correct steering.
New inserts for the wheels were nescessary because the turningpoint is moved further inside the rims....
The fender brackets is also redesigned. John Deere calls the mounting 'pro pivot' as the fenders is allowed to turn when they hits the tractorframe. These do the same. Two square tubes are held together with a piece of shrink tube.....
Turning radius is cut down with 15cm..... to 37cm. Very close to the original, 1:1 scale.
Thanks for watching!
Anders Kolpen
Denmark
Hy Anders,
sorry my English is not so good. It´s a sweet little John Deere. Do you paint the Plastik parts?
Greets from Germany
Kolpen
Yes, the plastic parts are all painted. Just not the hood and roof.
But all other parts have got the same color as the frame now.
Thank you for notice... Augenzwinkern
